SL Talisker for sale in Scotland
Posted: Wed Mar 29, 2017 9:09 am
Hull: Indian Runner 21 designed by Selway Fisher. Built & Fit out 1998 by Tom Peebles. LOA: 21' 0", LWL: 20' 0", Beam: 5' 6", Draft: 1' 9",
Strip plank, cedar and epoxy composite. Teak decks, Red Cedar strip planking in epoxy/glass. Full length canopy and see through side curtains
Boiler: Roberts type HWT designed & built by Antony Bever at Swindon in 1994
Coal fired, 165psi. 8” diam x 24” long steel drums, 28 x 5/8th steel tubes welded construction. retubed 2010
Condensing, engine driven pump, hand pump, injector, steam feed pump, feed water heater, whistle.
Engine : 2 cylinder compound 2 1/2 “ + 5” x 3” Power: 7 Hp
Built 1998 by Philip Newman at Abernethy. Savery style by Gordon Cheape. Piston valves, Joy Radial valve gear.
Hypro feed pump by chain stepped up 2/1 from front of crankshaft.
Edwards style air pump from LP crosshead.
Propellor: Manganese bronze, 3 blade right hand 16” x 30”. Shaft 1 ¼” stainless steel.
History: Hull built and fitted out by Tom Peebles (1993 – 1998).
[img][img]Trailer:[/img][/img] 4 Wheel with cushion boat side supports and guide posts.
More information on http://www.steamboatassociation.org.uk/page-1117882
Sale includes all above plus ropes, fenders, flag staffs, and other steaming paraphernalia as well as a Honda 2.3hp outboard (Hull has trap door to fit outboard in emergencies)
In first instance, contact Roger Martin on 0141 776 4430 or roger@martin04.plus.com to discuss details and price. Boat located in Lenzie by Glasgow for viewing.
