Realtime Steamup "Wayward Belle"
Post by TahoeSteam » Fri Jun 09, 2017 5:12 pm
Testing out my new 4k camera...
Real-time steam-up from cold:
Re: Realtime Steamup "Wayward Belle"
Post by Lopez Mike » Sat Jun 10, 2017 12:36 am
Having watched this process in person it is the most alarmingly complex power plant that I have ever seen and it runs like a watch. I am so impressed.
That said, I like my crude setup for it's own virtues.
Post by cyberbadger » Sat Jun 10, 2017 1:49 am
Really like the video, very well done. As I said on youtube, 4-5minutes is very impressive. Nyitra takes a min of 30min, but it's probably closer to 45min.
I for one do not understand the whole process. I get the boot strapping the kerosene with the acetylene to get the vaporizer hot. The pump, are you recirculating water? How is the fuel sprayed, pumped?
Post by TahoeSteam » Sat Jun 10, 2017 4:34 pm
You're right Mike, it is incredibly complex! I wish I could take credit for the design and manufacture of it, but the credit all goes to Charles Grosjean.
With the pump I'm initially only pumping fuel until I get 50 psi and 300*f steam, then I close the bypass and pump both fuel and water. (Fuel pump and feed pump on opposite sides of the pump ram) I close the boiler top drain and open the main steam stop, then I can start warming the engine.
