Forgings/Castings for Leak Compound?
malcolmd
Post by malcolmd » Wed Jul 11, 2018 4:14 pm
It looks like I need to make a new crank for my Leak Compound, and I was wondering if anyone is aware of a supplier of blank forgings or castings for the crankshaft?
Malcolm Duckett
Befur's Blog
Boat Name: Platypus, Shelduck
Re: Forgings/Castings for Leak Compound?
Post by RGSP » Thu Jul 12, 2018 7:38 am
Hard luck Malcolm, that's a real pain.
Phil Webster built his own Leak Compound for Banjo: I'll ask him what he did for the crankshaft. He has a Colchester Student lathe, so doing his own machining would have been just about possible given care and time. By the way, Banjo is back in action, having had heavy hull repairs over the winter, and her boiler re-tubed.
I did pick up that a longstanding local engine rebuilding company would grind cranks right down from the original forging if need be, but of course that doesn't help with getting the new forging (or SG casting).
malcolmd
Post by malcolmd » Thu Jul 12, 2018 7:52 am
RGSP wrote: Phil Webster built his own Leak Compound for Banjo: I'll ask him what he did for the crankshaft. .
Thanks that would be interesting. ..
Malcolm Duckett
Befur's Blog
Post by RGSP » Thu Jul 12, 2018 10:06 am
Just heard back from Phil.
Friday steaming in Banjo is resumed: all welcome (I know it's a long way, but beds here are available if you fancy a change, & I'd be happy to drive you up to Phil's, which is about 35 miles).
Phil made up a crankshaft pattern out of wood, & then had it cast, followed by commercial grinding. He says it's not perfect, but has steamed for 14 successive years without problems. I can no doubt find out where he had it cast if you need the info, but it may well have been at Thurton Foundry, which is now defunct.
Dick
Boat Name: Otter
Post by barts » Thu Jul 12, 2018 12:41 pm
Hi folks -
Is there any way to save the old crank, or is it cracked or bent beyond possible repair? Metal-spraying can save a crank that is simply worn.
