Neat Site
csonics
Anne from Little Britan
Neat Site
Post by csonics » Wed Jan 06, 2010 5:57 pm
Here's a cool and detailed site by a guy who built his own small compound:
http://aldunlop.com/Dunlop1.375X2.5X1.7 ... ction.html
Johnlanark
Re: Neat Site
Post by Johnlanark » Sat Jan 09, 2010 5:06 pm
That's a nice engine and some interesting machining techniques.
I note that Al is using aluminium pistons. This will keep the reciprocating weight down, but somehow I had a notion that iron should be used with steam. Anyone? John
Re: Neat Site
Post by barts » Sun Jan 10, 2010 5:41 pm
Johnlanark wrote:That's a nice engine and some interesting machining techniques.
Aluminum works fine for steam engine pistons at traditional pressures and temperatures. Those running 1000F superheated steam need not apply....
One does need to consider the 3x larger thermal expansion rate of aluminum.
Maltelec
Master of the Forum
Master of the Forum
Re: Neat Site
Post by Maltelec » Sun Jan 10, 2010 11:49 pm
I can't see any problem with aluminium pistons in the engines we use. Its only when aluminium overheats that it causes problems, and it will only overheat if the friction is too great.
The piston rings should be the only thing touching the pistons anyway, and they shouldn't move much on the piston.
mcandrew1894
Re: Neat Site
Post by mcandrew1894 » Sat Jan 16, 2010 10:35 pm
I run aluminum pistons on my compound at up to 165 with no issues thus far....saturated only.
Re: Neat Site
Post by 87gn@tahoe » Tue Jan 19, 2010 6:52 pm
if you were worried about wear in the ring lands or elsewhere on an aluminum piston (
as well as corrosion), you could always have them type 3 hardcoat anodized.
