1911 "Lune Valley" Savery 32HP Compound steam engine.4+8x5
$12,000 Can. Western Canada
Has vacuum and feed pumps,plus small air compressor and thrust block mounted.
Good condition.Needs to be in someone's boat.
Savery compound
Savery compound
- Screen shot 2017-01-29 at 3.06.06 PM.jpg (89.59 KiB) Viewed 9298 times
Re: Savery compound
Mike, what a beautiful job!
What did you set the clearances to on the bearing surfaces?
Re: Savery compound
Thanks! We put back all the shims as removed,giving,if I recall correctly,around 5 thou on mains and rods.We were very lucky with the dozens of pins and bushings of the valve linkage;it is all as built no lost motion.The center main has been turned down during the last century,the bearing itself resized.The bearings are huge,all bronze.All in all it turned out nicely,the engine being in good shape,and ,equally important,COMPLETE! It will look really nice in a thirty-ish foot boat,but I have too much on my plate right now. Mike
Re: Savery compound
Really looks good cleaned up and back together. I was interested in it, but I have too many projects going now.
Re: Savery compound
Sale pending Mike
Re: Savery compound
Mike, did this engine ever sell?
