Looks like it may go for a low price??
https://www.ebay.com/itm/264000602073?ul_noapp=true
Steam engine on Ebay low price
Re: Steam engine on Ebay low price
Would I be wrong to suggest that as it seems to have no revrsing gear, it is more likely to be a workshop engine than a launch engine.
It appears that the inner, smaller diameter, flywheel is a handwheel for the slip-eccentric reversing gear.Mike Rometer wrote: ↑Sun Oct 28, 2018 7:11 pmWould I be wrong to suggest that as it seems to have no revrsing gear, it is more likely to be a workshop engine than a launch engine.
I did look closely at that and thought perhaps it wasn't, but then what else might it it be?
It killed the cat you know.
Curiosity!
Curiosity!
I can't believe the high bid was only 250 dollars, it's worth that as a doorstop. I would've bought it myself, but I have enough stuff to trip over in here now.
Pretty sure it had slip eccentric, if ya look at the one pic it shows the small wheel rotates a hub around inside the eccentric.
