Posted on behalf of steamboatjack:
steamboatjack
Urchin
Posted: Sun Sep 14, 2008 2:49 am Post subject: cylinder drain cocks
Does anyone out there in U.S.A. or anywhere know where I can find some good bronze cylinder drain cocks for two Elliott Bay engines I am building? I am having trouble sourcing any here in U.K.
I would really like to use a single cock per cylinder (fitted on the lower end the upper end connected via a pipe) the cock shuts off both at once.
Klinger sleeve packed would be ideal but a quality taper cock with packings would suffice.
1/4 or 3/8 threaded B.S.P. ideally but could convert from N.P.T.
steamboat jack
Back to top
Posted: Sun Oct 12, 2008 6:55 am Post subject:
I eventually find almost everything I need on e-bay. You can define a search, and they will e-mail you when an item comes up for sale. I would suggest this search:
(valve*,cock*) (1/4,3/8)
This will get you all valves and all cocks, which are either 1/4 or 3/8 size, and this would be a large amount of information to examine. You could also just search like this:
drain cock*
This will get you all listings with "drain cock" and all listings with "drain cocks". The asterix (*) allows any character following the letters, often used to include the plural (more than one iof the searched item for sale).
Moderator: csonics
