Ashton Valve Co. 1871
Re: Ashton Valve Co. 1871
Ashton gages #109
- Ashton gages 109 1.jpg (48.47 KiB) Viewed 17855 times
- Ashton gages 109 2.jpg (57.67 KiB) Viewed 17855 times
- Ashton gages 109 3.jpg (52.41 KiB) Viewed 17855 times
Indicating or recording pressure and vacuum gages #105 B
- Ashton indicating or recording pressure and vacuum gages 105 B 1.jpg (52.88 KiB) Viewed 17854 times
- Ashton indicating or recording pressure and vacuum gages 105 B 2.jpg (73.27 KiB) Viewed 17854 times
- Ashton indicating or recording pressure and vacuum gages 105 B 3.jpg (68.25 KiB) Viewed 17854 times
#105 B
- Ashton indicating or recording pressure and vacuum gages 105 B 4.jpg (76.88 KiB) Viewed 17853 times
- Ashton indicating or recording pressure and vacuum gages 105 B 5.jpg (83.45 KiB) Viewed 17853 times
Ashton steel tube gages #111
- Ashton steel tube gages 111 1.jpg (41.96 KiB) Viewed 17850 times
- Ashton steel tube gages 111 2.jpg (77.59 KiB) Viewed 17850 times
- Ashton steel tube gages 111 3.jpg (74.4 KiB) Viewed 17850 times
#111
- Ashton steel tube gages 111 4.jpg (62.65 KiB) Viewed 17849 times
- Ashton steel tube gages 111 5.jpg (54.47 KiB) Viewed 17849 times
Master pressure and master pilot gages #101 D
- Ashton master pressure and master pilot gages 101 D 1.jpg (64.12 KiB) Viewed 17823 times
- Ashton master pressure and master pilot gages 101 D 2.jpg (56.52 KiB) Viewed 17823 times
- Ashton master pressure and master pilot gages 101 D 3.jpg (65.44 KiB) Viewed 17823 times
101 D
- Ashton master pressure and master pilot gages 101 D 4.jpg (67.05 KiB) Viewed 17822 times
Master pressure and master pilot pressure gages #101 F
- Ashton master pressure and master pilot pressure gages 101-F 1.jpg (58.98 KiB) Viewed 17821 times
- Ashton master pressure and master pilot pressure gages 101-F 2.jpg (80.66 KiB) Viewed 17821 times
- Ashton master pressure and master pilot pressure gages 101-F 3.jpg (69.75 KiB) Viewed 17821 times
101 F
- Ashton master pressure and master pilot pressure gages 101-F 4.jpg (75.4 KiB) Viewed 17820 times
I recently picked up an old Ashton Valve illuminated gage. It came without the lighting piece but I rigged up a light with a table lamp repair kit. Too bad in a way as I would have loved to see what the lighting unit from the 1930's (my estimation) would have looked like.
