Propeller shaft
froya66
Boat Name: Frøya
Propeller shaft
Post by froya66 » Thu Jan 21, 2016 7:34 pm
Is there a rule of thumb regarding diameter of propeller shaft.
Propeller size - 19 X 23", 450 - 500 RPM, 4 SHP. No heal - no intermidiate bearing - propeller direct at stern.
Will 3/4" do or should it be 1"
Jørgen
Re: Propeller shaft
Post by barts » Thu Jan 21, 2016 7:52 pm
http://www.aqualoy.com/shafting.asp
Depends on the material you use for the shaft. 1" would work w/ any of them.
Also, check maximum unsupported length calculation:
http://www.pacificmarine.net/engineerin ... pacing.htm
froya66
Boat Name: Frøya
Re: Propeller shaft
Post by froya66 » Sat Jan 23, 2016 9:45 pm
Thanks Bart
That was very helpfull :D
Best regards
Jørgen
