Funnel height ?
ianrichards
Boat Name: Isambard
Funnel height ?
Post by ianrichards » Sun Dec 03, 2017 3:13 pm
I’m assembling the funnel from stainless tube.
The main inner flue has yet to be cut to length, but the outer sleeve has already been cut to 36”.
What length should the inner be?
I have been told that is does not need to be the same length as the outer.
Advice greatly appreciated.
Thanks
Ian
Mike Cole
Boat Name: Blue Buccaneer
Re: Funnel height ?
Post by Mike Cole » Sun Dec 03, 2017 5:22 pm
Hi Ian
assuming that you are going to fit them to the boat together as one unit then just a few inches lower than the out casing should do.
Mike Cole
ianrichards
Boat Name: Isambard
Re: Funnel height ?
Post by ianrichards » Sun Dec 03, 2017 5:37 pm
The inner fits on a stump and then the outer slides will over.
So there’ll be two separate components
Ian
PhilMart
Boat Name: Adamant
Re: Funnel height ?
Post by PhilMart » Fri Jan 05, 2018 5:25 pm
My personal preference is the other way round! The inner projects an inch or two above the outer!
Mike Cole
Re: Funnel height ?
Post by Mike Cole » Fri Jan 05, 2018 6:34 pm
Well the answer seems to be , a bit higher or a bit lower, take your pick. Like most things in steamboating, very rarely is there one correct solution.
Mike Cole
ianrichards
Boat Name: Isambard
Re: Funnel height ?
Post by ianrichards » Fri Jan 05, 2018 7:22 pm
Gone for lower ... but I've kept the off-cut ... I can always Gaffa tape it back if need be ;-)
Mike Cole wrote:Well the answer seems to be , a bit higher or a bit lower, take your pick. Like most things in steamboating, very rarely is there one correct solution.
