Blackstaff Boiler - Fuel conversion
Old Steamer
Steam on Deck
Steam on Deck
Boat Name: The Nell
Post by Old Steamer » Thu May 17, 2018 7:26 am
Does anyone have any experience of converting a Blackstaff 3-drum, WT, boiler from liquid fuel to coal firing? I have my reservations as loss of water in a copper boiler that has immediate fuel cut-off appears less problematic than loss of water in a copper boiler where the fire has to be drawn. However, I believe it has been done.
Any pointers and/or plans would be very welcome.
Thank you.
OS
Re: Blackstaff Boiler - Fuel conversion
Post by TahoeSteam » Fri May 18, 2018 6:42 pm
Other than what you previous mentioned I don't see any issues with burning solid fuel in a Blackstaffe boiler. I'm sure there are plenty out there that have done it. I think one of the factors in most using liquid fuel is the grate area being more restricted than say a Robert's style boilet due to the coiled tube arrangement, making solid fuel firing a little more challenging.
Check out the steamboat videos on my YouTube page: https://www.youtube.com/c/wesleyharcourtsteamandmore
Old Steamer
Steam on Deck
Steam on Deck
Boat Name: The Nell
Post by Old Steamer » Fri May 18, 2018 6:56 pm
Wesley,
Thanks for comments. Since penning the above, I have done more research and found that coal-fired Blackstaffes are more common than I thought. All I need now are the plans and if the SBA plans service wakes up, I may have those - I hope. If not I still hope for a response from here. They must be out there somewhere.
OS
Post by fredrosse » Sat May 19, 2018 6:12 am
Having some trouble understanding your post. On loss of adequate water level, fire should be pulled or otherwise stopped from producing heat, independent of firing method.
Boat Name: Platypus, Shelduck
Post by RGSP » Sat May 19, 2018 7:03 am
fredrosse wrote:Having some trouble understanding your post. On loss of adequate water level, fire should be pulled or otherwise stopped from producing heat, independent of firing method.
I think he means it takes longer to damp down a coal fire than turn the fuel off to an oil burner. OK, it does, but the extra time shouldn't be a problem: the key thing is to notice promptly that the water level is too low in the first place.
Old Steamer
Steam on Deck
Steam on Deck
Boat Name: The Nell
Post by Old Steamer » Sat May 19, 2018 7:08 am
Correct - Shutting off liquid fuel is a matter of closing one valve; drawing a coal fire takes comparatively far longer. Perhaps not so critical with a steel boiler but more so with an all-copper boiler.
Post by DetroiTug » Sat May 19, 2018 3:25 pm
One thing to keep in mind with a solid fuel firebox, when the fuel door is opened, that in itself is pulling cold air in over the top of the fire which is going to drop the temperature of the flue gas.
Old Steamer
Steam on Deck
Steam on Deck
Boat Name: The Nell
Post by Old Steamer » Sat May 19, 2018 3:33 pm
To revert to the original question, does anyone have/know where I can acquire plans?
