Opposed Piston Engine Project - The Steam Version
Re: Opposed Piston Engine Project - The Steam Version
Post by fredrosse » Mon Apr 01, 2019 3:34 am
Lets say the engine with opposed pistons has two inch bore, and each crank has two inch stroke. With pistons at TDC there is only the clearance volume. At BDC each piston moves away from TDC two inches, thus engine displacement cylinder area x total four inches TDC to BDC = Pi X 4 = 12.56 cubic inches. This is the engine's displacement, and during the time period from TDC to BDC, 180 degrees of crank rotation, 12.56 cubic inches expansion occurs.
For a conventional engine of the same displacement, say a single acting engine two inches bore x four inches stroke, it will experience the same TDC to BDC expansion in 180 degrees crank rotation. Both engines, if the same displacement and RPM, will experience the same expansion rate.
So much for the mechanical aspects of this condition, but now lets look at the thermodynamics and transport phenomenon of steam expansion in a cylinder. The rules of engine expansion say that the rate of expansion, fast or slow, does not necessarily change the wetness of steam during expansion. Steam turbines expand steam many many times faster than any reciprocating steam engine, yet that rapid expansion does not produce any extra wetness in the exhaust steam. What does matter during the relatively long period of expansion in a recip, is the heat transport, or heat transfer that so severely limits the efficiency of steam engines. Initial condensation on live steam admission, and continued condensation during expansion in the cylinder take a serious toll on engine efficiency. The faster the engine runs, the less time there is for condensation due to heat transfer, but both of the engines described above have the same time interval for extra condensation, and very nearly the same heat transfer area exposed for producing cylinder condensation, hence virtually the same performance potential.
Post by fredrosse » Mon Apr 01, 2019 11:30 am
" I need one of these crankcases for each end of the cylinder. And each of them is divided along the axis of the crankshafts to make it possible to insert the crankshaft. It is not an optimal solution to have ball bearings in a split bearing block, but I'll see how it gonna work."
Why not make the main bearing end caps each as a single piece, with the square (or rectangular) tubing large enough to allow removal of the crank/rod/piston assembly without the need for a horizontal split crankcase? This is essentially the way many small two stroke engines have been configured. Then the crankshaft main bearings are not in a split bearing block. This is a solution that would be far easier to make, as well as better structural integrity, and less difficulty in reliably sealing this setup. This is at the expense of using bigger square tubing for the crankcase(s), probably not much of a penalty in this application.
Post by DetroiTug » Tue Apr 02, 2019 4:57 pm
Someone was talking about an engine like this a while back on the Steam car forum. There is some misconception that, the cranks will split the loading that is normally on one crank, not true, there will be two cranks with equal loading and and the same as one, and there are some disadvantages mechanically - shorter stroke equals higher loading on the rod throws for the same torque, also some sort of mechanical synchronized coupling and the associated resistance. The same for the "double the expansion area", also not so, as Fred aptly points out above. I'm not seeing any advantage to this engine design for steam?
Post by fredrosse » Tue Apr 02, 2019 11:01 pm
"So if there is no advantage to this engine concept, why was the airplane engine, and many submarine engines made this way?"
The only advantages I see is lower piston speed, the double crank engine has virtually half the piston speed compared to a single crank, and that represented a serious limitation on stroke/RPM considerations. Also engine balance can be much better having two crankshafts opposing each other, at the expense of all the drive gear between the cranks. Maybe the opportunity to make things more compact in certain applications. For a Diesel setup, cylinder scavenging with pure air without poppet valves, without camshafts, would offset the fact that there is similar mechanism to a typical OHC configuration, only more robust.
Maltelec
Master of the Forum
Master of the Forum
Post by Maltelec » Wed Apr 03, 2019 9:17 pm
TriangleTom wrote:
Sun Mar 31, 2019 6:00 pm
That's a really clever and fascinating design. How do you anticipate dealing with condensation in the crankcase?
Very simple, there is no crank case.
Ramón
Post by Ramón » Mon Apr 15, 2019 1:24 pm
The idea with the one-piece crankcase definitely sounds like the sturdier solution. The only problem is that the crankshafts I am using have one-piece con rods, which I couldn't detach from the crankshaft. (Maybe that is why you are suggesting a bigger size of the crankcase - to have enough space to get it out with the con rod) This means I couldn't remove the crankshaft axially through 'the tunnel'.
I know it is not a mechanically smart solution, but taking the proper dimensioning for the bolts and the small size into consideration, it shouldn't be a big problem until I figure out a better solution.
To update you, I am fighting a pitched battle to make the lathe work. That is why I am delaying. The universal motor scavanged from a washing machine works, though it only turns at an unsatisfactorily slow speed. I am trying to figure out a solution for that before I can turn stuff on the lathe. But I am almost there. Be patient:)
Actually, the animation with the single-crankshaft-engine Maltelec shows on the 3. page of this thread is the thing Mike Rometer suggested n the 2nd page. I find it amazing, that people even desi´gn high rpm (in comparison to stereotypical steam engines anyways) with so much linkage. It looks so fragile and prone to not working in the long run. Too many moving parts for my liking. Though I might be misled. With the proper bearing sizing, material choice and shaping of the parts, it should be no problem. But I prefer the solution with 2 crankshafts.
By the way, using no crankcase is no option for me. If the engine will work as thought out, it will have rpms to the lower thousands. That means I am using the crankcase 1. as a sturdiness supplier and 2. as a means to confine the lubricant being thrown at me;)
