Vacuum gauge location
- Boat Name: Precious Bane
Another question: I should like to put a vacuum gauge on my condenser. So where do I tap into the system? If I were to tap in just before the thru hull below the engine exhaust, I imagine I would see a lot of bounce in the gauge from the exhaust pulses. If it were tapped into the air pump side would I see bounce from the air pump. Which is worse. I plan to use a snubber before the gauge and a long pig tail to the gauge to soften any gauge bounce. Again, Thanks.
Re: Vacuum gauge location
Hi Chris,
I believe nearest to the exhaust if the engine will give you the most accurate measurements. A snubber or valve can throttle pulses down to nearly imperceptible and be of no consequence to your gauge. Also, being on the "hot" side of the condenser there's less of a chance of things being filled with water and becoming a PITA to drain for freezing winter temps.
A bit off topic but when doing a winter drain I have given up on compressed air. Besides multiple disconnects in the piping and a final warming of the boiler, I have made an adapter fitting for my wet or dry shop vacuum that includes a short length of clear tubing.
Volume rather than pressure is the trick. And being able to see when there is no more water being sucked out is a great help. I use this as well on my house water piping when the drizzle sets in and I flee to Mexico for the Winter.
Hi,
best position to connect the vacuum gauge is near the output of the condenser.
Here some pics of rainers solution. He has installed a inbord condenser followed by an condensate collecting reservoir. The gauge is connected at the far end of the reservoir.
(all pics offered at https://steamboating.de/emma/dampfboot-emma-0130.php)
Dietrich, that is a gorgeous engine!
Gauge snubbers are somewhat expensive.
To dampen pulsations on a condenser line, use a long piece of silicone tubing, the elastic nature of the tubing will act like a damper (snubber) to decrease the magnitude of pulsations. Silicone is good for condenser temperatures. Small tubing, about 3mm inside diameter, coiled with about 2 M of tubing will help, although the amount of snubbing action depends on engine and condenser.
Adding a small reservoir between the tubing and gauge will further the damping action, about 4 inches of common 1/2 inch pipe will almost eliminate all pulsations.
