Boiler Bushings for VFT
- Boat Name: ST Mariana
i am starting to make the bushings for the exterior boiler fittings. Just spent an hour looking at ASME code B31 but could not come up with an A number for the quality of steel for the raw slug. I will bore, thread, and put an exterior taper on it. Does anyone know what quality steel I should use?
Re: Boiler Bushings for VFT
Any particular reason you're not using thread-o-lets?
https://bonneyforge.com/products.php?pg ... =thredolet
- Kelly Anderson
- Boat Name: Vividus
You can use SA 105, SA 675, or SA 696. You can buy A 105 half couplings from McMaster to save some time. https://www.mcmaster.com/4513K77
