To get a triple
Re: To get a triple
Post by barts » Mon Nov 30, 2009 12:35 am
And I too would very much appreciate a copy of your paper....
Ralph B
Re: To get a triple
Post by Ralph B » Mon Nov 30, 2009 7:08 am
I downloaded Stumpf's book and have been easing my way through it. I am slowly coming to the realization that a 3 cylinder uniflow would be a better fit...smooth operation, and should be very reliable...if one or even 2 cylinders go down you can still run. The hard part is finding a proven design.
Anyone have a 4hp (or bigger) proven design they would like to sell?
Re: To get a triple
Post by fredrosse » Tue Dec 01, 2009 5:07 am
The Domestic Heat-Power machine burned anthracite coal, using an automatic stoker, running 24/7 requires a fully automatic plant. Send me your e-mail in a PM and I will forward the paper. I will not use the e-mail address for anything else.
A very high efficiency 3 cylinder uniflow engine was used to generate 25kW at the Whitecliffs Solar Power Plant in Austraila. Lookup details of this machine on the Internet.
Ralph B
Re: To get a triple
Post by Ralph B » Tue Dec 01, 2009 9:26 am
I looked at the White Cliffs design, they use a converted Lister and use an interesting valve operation. I also went to Elpenor's site. Does anyone know the hp rating of that engine?
artemis
Boat Name: Pond Skimmer
Re: To get a triple
Post by artemis » Tue Dec 01, 2009 10:26 pm
Ralph B wrote:...I also went to Elpenor's site. Does anyone know the hp rating of that engine?
According to a very comprehensive article on the building of that engine that David Ayers wrote for/and was published in Steamboating Magazine, at 320 rpm, 100psi, 45deg cutoff (about 1/6 stroke), 27" vacuum the HP rating is 8.
Ron Image
Ron Fossum
Steamboating Magazine Editor
http://www.steamboating.org
Re: To get a triple
Post by barts » Wed Dec 02, 2009 6:31 am
Don't underestimate the simplicity and reliability improvements you'd get from a big single cylinder uniflow... with a overhung crank, you can easily use roller bearings for the crankpin, and mains can be tapered roller bearings or babbitt if you prefer. With poppet valves, a proper maneuvering cut-off (at least 50%) and auxiliary clearance space to reduce compression under low vacuum conditions, you shouldn't have any problems with the engine failing to reverse reliably.
artemis
Re: To get a triple
Post by artemis » Wed Dec 02, 2009 8:31 pm
barts wrote:Don't underestimate the simplicity and reliability improvements you'd get from a big single cylinder uniflow... with a overhung crank, you can easily use roller bearings for the crankpin, and mains can be tapered roller bearings or babbitt if you prefer. With poppet valves, a proper maneuvering cut-off (at least 50%) and auxiliary clearance space to reduce compression under low vacuum conditions, you shouldn't have any problems with the engine failing to reverse reliably.
Yeah, and you don't have all those tiny parts to wear out rapidly (wrist pin knock, etc.). :o
Ron Fossum
