Can't log onto the forum?
Want to know a general knowledge question? Or think you can answer some simple questions? Have a look here.
Locked
Maltelec
Master of the Forum
Master of the Forum
Post by Maltelec »
If you find your user name and password don't let you log on to the forum, have you tried the following:
1. Have you registered on the new forum? I couldn't copy across the membership database so everyone will have to register on this forum.
2. If you have registered, are you using the correct URL (address after the http:// bit)?
If you see: http://80.82.121.119/forum in your address bar, this is wrong and will cause login problems. Instead, please use: http://www.thesteamboatingforum.net/forum
Locked
