Re: single expansion crank angle
Posted: Fri Feb 01, 2013 4:27 pm
I sense a misunderstanding here (I may well be wrong).
The confusion is between crank lead and cylinder lead.
Regardless of forward or reverse, the steam will always enter the HP first, as the LP is supplied from the HP exhaust (normally, but not let's get into that), so the LP never leads. Direction is only achieved by which END of the cylinder is fed first, not which cylinder. The change is done in the valve chest, so effectively there will be no noticable difference in power in either direction.
There is still a power pulse every 90degs whichever way it is turning.
