I've had good results building tanks two different ways. Leaving out such wonderful things as welding them up from metal (a good way to go).
I have built them from plywood and epoxy pretty much like the stitch and glue dingy methods. The water tanks in my sailboat have made it 25 years and a circuit of the Pacific Ocean so far.
I have built some motor vehicle tanks from sheet ABS plastic and ordinary ABS pipe cement. It is a homogenous joint and amazingly tough. I just glue in ABS pipe fittings wherever needed a bit like weldolets on a steel boiler.
In both cases the side of the tanks against the hull can be curved to fit.
Specs for my dream steam launch?
Re: Specs for my dream steam launch?
