Re: Hello
Posted: Sun Jun 28, 2015 12:26 pm
Sorry about the video links ,I will get some help from my kids .
Here is the youtube url for low fire https://youtu.be/fPr8s6nmsl4
and high fire https://youtu.be/rGmphfMhAOQ its hard to describe four years development of the system while learning how to use the forum , the principal of burning pellets is the same as any solid fuel the fire heats the pellets they give off gas which burns and in turn heats the next pellets and also the boiler so the fire pot needs to be a pot rather than a flat grate so that it heats the pellets efficiently .
My cast iron pot is 200 mm at the top and 150 mm at the bottom and I have an 8 mm threaded rod down one of the center fire tubes with the cast iron pot lid attached to it as a baffle to direct some heat up the outer tubes (don't laugh at how crude this is but it has worked perfectly for about 4 years now) you can see the latest feeder attached to the front of my boiler in the picture of my boat in my original post .
