Re: Stuart Sirus Engine
Posted: Wed Jan 25, 2017 3:20 pm
I located the "Firefly" (British radio generator set from WWII) manual, which uses this engine, and it describes engine startup and operation.
The manual just has a note to check the oil drain after every few hours of operation, and if water is present, drain down the crankcase plug until oil starts coming out, then top off to proper oil level. The setup also injects no cylinder lube into the steam, evidently the slide valve got enough lubrication by oil seeping past the pistons and getting into the exhaust steam.
