Knocking ??
Albert R
Boat Name: Min Deern
Re: Knocking ??
Post by Albert R »
Do not forget to check the stern tube bearing (especially if you have a rubber one). If too loose, resonance causes strange knocking at certain revolution ranges.
Albert
hedleypiper
Boat Name: justine elizabeth
Re: Knocking ??
Post by hedleypiper »
irregular Knocking solved I think! It seemed to come from the condenser.
Discharge pipe straight from the L.P. to condenser ( the preheater was collapsed inside so cut it off which might have started the problem) . Added a 'dibber' pipe to suck from the lowest part of the condenser and serviced the vacuum pump, to great good effect ! about -18psi shows on gauge.
Re: Knocking ??
Nicely done!
wsmcycle
Re: Knocking ??
Post by wsmcycle »
I'm not too up on this sort of esoterica.
This is the best reply ever!!!!! Oh that I could mingle with that!!!
LIGHT THE FIRE!!
Re: Knocking ??
Had a friend who was in Greece a couple of years ago and found out that these greek words mean something.
Esoterica meant a bus line that stayed within the city. "Something held within."
Also Metaphor was the name of the airport carts to haul your luggage. "To carry."
Who knew?
