That idea is news to me, and I wonder how you intend to get your boiler completely full? I generally leave mine fairly full, but short of fitting a hand pump and pumping until it all comes out the safety valve, I can't see how you can do it. Its never been done with Zeltic's boiler, and there is no sign of any corrosion or damage at a certain part of the boiler.artemis wrote: When lighting off a vertical fire tube boiler, the boiler should be totally filled with water before the fire is lighted. Once steam begins to form, the water should be "blown down" (here's where a surface blow down valve/connection is desireable) to the correct level. The area of the tube(s) above the water is now partially protected by steam. Your VFT boiler will last much longer is this rule is observed.
