B&W Type Watertube Boiler Upcomer Penetration Question
Stirring the Pot
Stirring the Pot
Boat Name: Steam Queen
Re: B&W Type Watertube Boiler Upcomer Penetration Question
Post by farmerden »
The pumps are both driven off of the LP rod with a simple rocker assembly.The boiler feed is nothing fancy -just a 5/8 in displacement style pump the other pump is an Edwards type pump which works well for me but there has been discussion somewhere in this forum that this style doesn't always work well in this application.
Den, that is a beautiful engine. Did you make that? What are the dimensions?
The price of a copper boiler will be quite a bit more than you welded specimen me thinks.
JonRiley56
Post by JonRiley56 »
Hi Den,
Gorgeous engine !!!! If you get a chance and it is not too incovenient, do you think you could take a close up of the linkage between the pumps and the engine ? I am going to be running a single cylinder that is set up with a side crank so I can only drive off one end of the shaft. I do have room for a couple of additional eccentrics though, so I could put two pumps across from each other, but I am wondering if I could do some sort of lever set up.
Have you seen anyone running a separate steam pump for make up water ? You would not have the constant hp drain when you are running, just a minor steam diversion when needed. I guess you also get the benefit of being able to supply water to the boiler without running the main engine................when you are at the dock refilling the cooler...........
Stirring the Pot
Stirring the Pot
Post by farmerden »
Wes Did I make it? You know me- I'm just a dumb log truck driver!! I shined it up!! :lol: Well OK I rebuilt it. George Doughty made two of these 2 3/4 X5X4 I own both It is a well designed engine and very easy running.
ImageImage[/img]
We should have an engine and boiler picture thread... For that steam porn.
Sorry for the thread jacking.
Stirring the Pot
Stirring the Pot
Post by farmerden »
jon scroll down in this section to the bottom of the first page "do I Need This?" I asked that very question about a steam pump and got some good answers Den
