Re: Ball bearing eccentric
Posted: Mon Mar 07, 2016 5:46 am
I checked out the Watt's linkage by constructing appropriate arcs in the CAD system. Peak error (deviation from linear motion) on an engine this size is +/- .020", which is high for uniflows since the piston is so long. It did occur to me while at the pub last night that one could mirror image the linkage on the other side of the cross head; this would convert the error to a twisting motion - ok w/ a spherical roller bearing big end and on the Watt's rocker , but it's all getting too complicated
I also ran the numbers for cut-off at 40 degrees after TDC; crosshead bearing loads up somewhat, but still easily doable w/ 4 square inches of SAE 660 bronze bearings... very handy that the peak cross head load is not also at the peak velocity. 100% cut-off engines have a hard life.
Detroit Tug, I'm going to try your idea of a cross head guide on either side of the piston rod, but use bronze bushings with a small oil reservoir and felt oil seals instead of linear bearings. They will be running on the same R60 case-hardened ground shafting, though. The supports for the cross head guides will tie the columns together, and turned rods will in turn tie the two sides together.
