I successfully did a washout of the new boiler with trisodium phosphate and soda ash to clean any residue and to prep the interior steel surfaces for the water treatment I use.
- Boiling with Trisodium Phosphate + Soda Ash open to the atmosphere to clean and washout the boiler.
- Boiler_Washout-Boiling-Open-Atmosphere.png (112.84 KiB) Viewed 17916 times
Then this friday a lot was accomplished in the first steam of this new boiler, my steam buddy helped me a lot.
All land based, stationary steam at this point. It's about getting the boiler plumbed and working the way I want before I really think about putting it in eventual hull.
We made steam up to 200PSI, we ran a steam engine to make electricity, we installed and tested an untried steam injector, we installed and tested the new ASME Safety Relief Valve, we installed and observed the two Pressure Gauges for the boiler, we installed and observed an analog water temperature gauge, we tested and observed the water level using the three trycocks and sight glass, we installed and tested a steam siren, and probably more I am forgetting...
- First Steam. Land based stationary - generated electric(light) as a load using an engine made by J Winn from England
- firststeamup.png (110.84 KiB) Viewed 17916 times
