Towards Building a Steam Powered Outboard Motor
Elver1
Re: Towards Building a Steam Powered Outboard Motor
Post by Elver1 »
Elver1
Post by Elver1 »
Register turned:
Elver1
Post by Elver1 »
Drilling shaft clearance space in the bearing housing:
Elver1
Post by Elver1 »
Boring the inner bearing recess:
Elver1
Post by Elver1 »
Inner bearing mounted:
Hello,
looks fine.
How will you lubricate them? What about 2RS ball bearings?
Elver1
Post by Elver1 »
Hi Dietrich, thanks for commenting! :D
The inner bearing here is inside the crankcase (oiled). The outer bearing, not yet installed, will be a 2RS. Next step is shortening the tubular part of the housing to finished length, and then boring the outer bearing recess. The tubular part was left long for easy chucking up to this point.
I like your engine very much!
Elver1
Post by Elver1 »
Cut down the length of the bearing housing, and bored the outer bearing recess:
Elver1
Post by Elver1 »
Spotting the bearing housing flange against the crankcase:
Elver1
Post by Elver1 »
Drilling tap size:
