Thank you for your answer.
I quess it really shows up eventually if you buy cheap tools. As a student, I was only able to buy a relatively cheap drill press, whose drill table bends down under very little pressure. Now, I just use a short length of a very big suspender as a table and it works better (plus the periodical shifting of the work piece that is)
Now, my most urgent goal is to replace the electric motor of the lathe since there was no way to make the washing machine motor run fast even without load - even after trying every possibility to connect the 5 cables of that motor to the 2 power cables. Gee I didn't know it was so difficult to get a good electric motor. But now I ordered one coming next week. And THEN it gets interesting using the lathe. Before I turn all the pieces neccessary, I will upload all the pieces the core of the engine will be machined from. After I build it up, I will do a second round ordering all the metal for the valve mechanism.
Liberty ships had been built faster:) but at least the project grows.
Opposed-Piston Engine Project - The Steam Version
Re: Opposed Piston Engine Project - The Steam Version
To show now what I did and what I didn't do yet: The last piece of metal for the core engine arrived friday. As I explained, I split the building process into two stages:
As I already promised TahoeSteam a long time ago
, I now show you all a photo of all the pieces I need for the first building step:
I arranged everything in an appealing pattern:
Until now, I've been prevented to reach my goal by this:
This is a mediocre picture of the headstock and cross slide of my home built lathe. It is off topic, but maybe someone might be interested in it: Some shipyard worker must have built it and I found it in a dusty, old 6-storey store house with an antique's trader in it. I immediately fell in love with the old DIY work. I couldn't pass, knowing it might one day be scrapped. Only the headatock was extremely weak and worn. Now it got a headstock welded together with 20mm(3/4inch) steel plates. The industrial bearings hold a 2 inch spindle. It is way oversized, but once it is finished, it will be a very sturdy lathe.
What I am still thinking about is some considerations about the lubrication and the addition of an oil drain plug and a screw to fill it up(which might get a small 2mm rod brazed on for oil checks. I won't realize filtering and water removal on the single cylinder test engine. Only an oil pump needs to be added to get to the top crank case, while a small connection down to the lower crankcase will provide for the back flow. But I just will use an electric pump for the first tests. The goal will be a mechanical oil pump driven by either the camshaft or another auxiliary shaft for all the pumps needed.
- The core of the engine: crank cases, cylinder, intake-& exhaust register
- The valve train: timing belt drive (probably), the cam axis, the centrifugal governor, the mount for the rotary encoder, the valve block
- The crankshafts both have open ball bearings, which will be isolated by simmer rings on the outer ends. I want to have the lubrication concept as simple and effective as possible. That's why I designed the ball bearings between the crank webs and the simmer rings. Thus, they will be lubricated by the oil inside the crankcase.
- The 2 small locking assemblies will attach the gear, whose task is to synchronize the 2 crankshafts. I abandoned the idea to link up the crankshafts with a bicycle chain and sprockets, as it is said to be a loud option (older car engines seemed to have a timing chain.)
- The cylinder will consist of a piece of 303 steel, as does in the uniflow steam engine of a friend of DetroiTug (viewtopic.php?f=8&t=567). I was intrigued by the above-mentioned material pairing and want to try it out myself. The cylinder needs the following adjustments: 2 identical pieces of an exact length needs to be turned. The inner diameter needs to be turned on both pieces. The exhaust- & intake ports need to be milled.
- The 2 crankcases will consist of all the pieces with the dark skin from the steel works still on. Things, which need to be done: The pieces need some more grinding to be done. After that, each pair of bearing blocks need the seats for the bearings and simmer rings turned. After that, 2 of them will be welded with one of the U-shapes in between to create the 4 of the crankcases. 2 of the 4 welded parts then need to be turned a last time down to a specific depth to receive the cylinder. Afther that, I will fine-tune the cylinder length.
- The large block of silverish metal with the blue foil on it is the piece of AlMg4.5 Aluminium for the steam intake and outlets. Things, that need to be done: 3 relatively square pieces need to be cut. Each of them need to be sawn in half and bolted back together. Then, each one of these need the outer diameter of the cylinder turned out and the channels milled on the lathe. Then, they just need some threaded holes around the channels to bolt the intake/exhaust registers to them.
Re: Opposed-Piston Engine Project - The Steam Version
As a major challenge in life has made me lose almost al my belongings a couple of months ago, including my workshop, I have to start anew.
I now have a garage I am equipping with new tools and everything to continue with my hobby. The good thing is, that I now can have a real workshop with ground-level accessibility (It WAS tricky having a workshop in a 8m² tenement building cellar.
Since the steam virus knows no cure, I'm still planning on building the opposed-piston steam engine project, the digital steam indicator and a gasoline-fueled monotube boiler.
I am now at the point of buying/organizing all the tools. Drill press, welder and a new lathe, which will be the most crucial part of the project. It will take some time, but the opposed piston engine is somewhat of a dream engine project for me.
I'm sorry to hear you went though a terrible time in your life. I hope you're able to build a new and better life from the ashes. I am happy to hear you still have the bug and are continuing to pursue your dreams. We are all looking forward to your updates.
Stay safe and healthy.
I am thankful for these words. At least any way from the bottom leads up.
Soooo
It is slowly getting interesting again. I am now in the phase of scratching together the materials. I was thinking of buying two of those bare chainsaw engine units:
I am thinking of cutting off the upper part of the cylinder block at the height of the bottom end of the piston in BDC and to use the remaining part as a flange to connect a new cylinder to it and the other shortened engine block respectively. The question is right now how I am going to accomplish this. The cylinder will be brass or bronze and the engine blocks are cast iron.
I can stick weld, but welding grey cast iron to brass/bronze - I don't even know if it's possible. I was thinking of brazing or bolting some kind of thin extra flange plate onto the cut and planed surface. That way, I'd only need to heat a small plate and the cylinder for brazing. I could squeeze the two engine blocks together with the cylinder in between, but I need any way of preventing the cylinder from being able to move sideways.
Does anyone have an idea?
If you machine away the cylinder head portion of the iron engine block, then bore into the iron cylinder a small recess distance (say, one mm) then your long cylinder will fit between the two engine blocks. To eliminate flanges and brazing, just use long tie-bolts to pull the two engine blocks together, which will lock the long new cylinder in place between the two engine blocks.
You may be able to use the original pistons in the engine as crossheads, with tubular columns leading to the steam pistons. This can largely eliminate side thrust on the steam pistons, as well as providing separation of the oil lubricated crankcases from much of the steam wetness.
Minerva was on my side. They placed a large container for bulky trash/scrap in the garage complex my workshop is part of. Besides a couple of still working fire extinguishers, construction wood and whatnot, I've found the upper half of a weed whacker with an engine, which is perfectly fine. I wasn't sure if I want to use it for this project or something else, but I discovered after a close inspection, that the engine possesses a separate cylinder flanged to the crankcase. So, a flange is the natural solution.
I had this idea of using chainsaw engines, because they possess a bearing on both sides of the crankshaft. This brings a lot of advantages for my project. I've seen some schematics of weed whackers with only a single crank web, which kept me from using them. But mine has two ends and I am now getting another weed whacker. They coincidentally don't seem to be high-value merchandise and I can grab another one for 10-20 bucks. Maybe I require a new piston, because there is the chance not every engine uses the same piston diameter. But well. Finally, there's progress.
