No the hull is an old logging tug but I extended the hull 5 ft. because it was so short and wide (10 ft. wide)
And yes the ratchet mechanism is clicking in reverse,
tried at first building a soundless but did not work so well (lots of smoke in the boat when it reversed)
the other blocking plate on top of the boiler is a soot hatch, It is convenient when you need to clean the air preheater
No not very loud, just a low humming at these speeds about 1500 rpm, tested to change gear ratios but where just more noise and burned more wood.
the fan comes from an air dryer from the 40s
