Posted: Tue Mar 20, 2018 5:12 am
Mike,
My only means of running a simulation is to CAD model the engine which is an enormous task and it requires hundreds of measurements from the engine or plans. I CAD modeled my entire 6A engine down to the last nut and bolt before I cut the first chip, this way I didn't waste a single minute making parts that were not going to be perfect and fit with everything else. The CAD model can be presented on screen with a section view cut through the model at any point and at any angle. The CAD model can then be rotated just as the real engine is rotated with all parts moving together in harmony. With the CAD model of my 6A I can change any dimension and see the resultant effect. For example I can change the eccentric timing, steam lap and exhaust lap on the valves etc.
In answer to your question, I am afraid that I don't have time to CAD model your entire engine. But you can easily make a study of your timing events by charting the timing at different shut off positions on the Stephenson's link. This can be a little challenging if you have a piston valve but it can be done and I am sure that you would find it to be an enlightening process.
Many people talk about the 6A blowing the valve off it's seat due to compression. I can say for a fact that this is caused by the HP eccentrics being too far advanced and the exhaust lap being too great in order to compensate. The shut off on the exhaust happens earlier as you adjust the Stephenson's link to shut the steam off earlier. So what you find is that before you get the economic advantage of shutting off the inlet steam earlier, the engine starts to bang and rattle due to over compression. Most people will say that they adjust the shut off until the engine runs it's smoothest. What they are really doing is finding the location where the poor valve events are causing the least negative effect. It would be true to expect the 6A to run more quietly with a piston valve, what is really happening is that the over compression on the HPis being masked by the piston valve (as it can't jump of it's seat) and not corrected, as it is a timing issue, not a slide valve versus piston valve issue. When I modeled the 6A with all dimensions exactly as per Stuart's drawing and adjusted the shut off to 50%, one side of the HP cylinder was closing the exhaust at 50% of stroke, and that is an awful lot of compression, especially with a compound where there may be 60PSI or more in the exhaust side of the HP cylinder when the exhaust valve closes. I did a lot of reading about valve timing and looked at quite a number of examples of timing on commercial marine engines, the HP side of the 6A was not at all similar to other examples. As you have mentioned in another post, there is a longevity advantage in balancing the HP slide valve in the 6A, this unfortunately adds to the problem of the valve being blown off it's seat. I changed the HP timing on my 6A from 40Deg advance to 30Deg, more in line with the commercial examples that I studied, the simulation shows massive improvement. With the inclusion of the center suspended link and careful calculation and testing of the position of the suspension pin, I can now change the shut off any where from 78% of stroke to 30% of stroke, and ALL events remain in balance between both ends of the cylinder within 2% across the range, in both forward and reverse. Not that reverse matters much in a boat. Good railway engines managed to get this down to 1%. A standard 6A with the valve gear made according the the Stuart drawings has balance errors of as high as 35% .i.e. the opening and closing positions of the ports can vary between one side of the cylinder and the other by up to 30% of the full stroke length when the engine is linked up. So you can set the 6A to be reasonably correct at one link position, but change the link setting and it all goes terribly out of balance. It sounds impossible, until you see the simulations.
As a matter of interest, my CAD software allows me to simulate and measure the dynamic balance of the engine, as the mass properties can be loaded for each material used in the engine, thus the software calculates the weight and balance of each individual part and combines and calculates them in the assembly.. This means that I can plot the correct counter balances necessary for the HP and LP, and yes they need to be different. I can change the material properties for say the pistons from CI to aluminum and instantly see the change in balance on the crank. Fun stuff, if you are naturally patient
