Page 8 of 8
Posted: Sun Nov 01, 2020 2:50 pm
by dampfspieler
Hello,
the condensers stand is ready. I have made it from 2 mm-brass sheet.
The stand
The stand
The connection hose between the condenser and condensate pump with receiver.
Best dietrich
Posted: Sun Nov 01, 2020 2:55 pm
by dampfspieler
Hello,
the condenser is mounted. The stand with inner clamp.
The engine with mounted condenser.
Best dietrich
Posted: Sun Nov 01, 2020 3:38 pm
by RNoe
That is a remarkably compact and clean installation.
Posted: Sun Nov 01, 2020 9:21 pm
by PeteThePen1
A marvelous piece of work and an example to those of us are rather less skilled metal workers. Please keep going as I want to see what you plan next.
Posted: Mon Nov 02, 2020 7:23 pm
by RNoe
I second Pete's comments.
Lets see it steaming a nice hull along the waters!
:lol:
Posted: Sun Aug 06, 2023 8:02 pm
by dampfspieler
today I successfully tested the condenser on my steam engine. Although the connections were only hand-tight and the vacuum manometer was only connected to the condensate collection tank in front of the vacuum pump with a silicone hose, a stable vacuum could be achieved.
The "Sound of Silence" of the engine was very impressive - there was nothing to hear. :o :o :o
Bildschirmfoto vom 2023-08-08 16-16-43.png (390.32 KiB) Viewed 143036 times
https://youtu.be/mP2uwwiujWk
I am really happy.
Posted: Sun Sep 03, 2023 7:37 pm
by dampfspieler
for those who might be interested in the build of the machine pump unit I show these two sectional images.
Posted: Sun Sep 03, 2023 10:29 pm
by Kelly Anderson
That is very beautiful workmanship. Thank you for sharing!!
Posted: Sun Sep 10, 2023 9:31 am
by dampfspieler
Hi Kelly,
thank you for the comment.
I have redesigned the piston and its rings. There was at first one O-ring as piston-ring. To achieve a better seal, i made a new piston in which i was able to install two X-rings as piston rings.
Posted: Sun Sep 17, 2023 8:47 pm
by TahoeSteam
Looking wonderful Dietrich. I expect you'll be seeing much improvement from the "x" rings.
