Specs
Posted: Fri Jan 18, 2013 11:30 pm
by johnp
What should i use for torque specs for rod bearing caps,main bearing caps and head bolts? 3/8" bolts, 5/16" bolts'
And plasti gauge bearing clearance?
Re: Specs
Posted: Sat Jan 19, 2013 3:11 am
by marinesteam
Snug them up until you let out a little involuntary grunt. That should be just about right. I'm sure that is how it was done in the
1890's. If it breaks you have gone too far! :D
Re: Specs
Posted: Sat Jan 19, 2013 3:41 am
Bearing clearances need to be tight on double acting engines to prevent knocks; they'll run quite loose for a long time but you don't get that nice silent glide :)....
.001 per inch in diameter seems a common middle of the road recommendation.
Re: Specs
Posted: Sat Jan 19, 2013 6:34 am
Re: Specs
Posted: Sat Jan 19, 2013 9:50 am
marinesteam wrote: If it breaks you have gone too far! :D
Then you need to back it off a quarter turn.
:lol:
