Progress on the boat
Posted: Thu Dec 26, 2013 7:42 pm
Setting aside my ambitious plans for the John Fitch, I step out into the new shop and start making real progress on a real boat. I was originally going to call her Modest, but given the manner in (and materials from) which the boat will be constructed, I think I will leave the name Modest for a skipper with a boat pretty enough to deserve it. My boat will be called Das Billige, or perhaps just Billige.
The project can be found here: http://s333.photobucket.com/user/Nbrent ... %20Project
I will give a short summary in this post (all the information below can be found in the pictures).
The plan is to make a sidewheeler. For the engine, a converted two-stroke. For the boiler, a no-weld Porcupine. For the hull, an aluminum canoe.
First, the engine.
After looking up several videos online about converting a two-stroke to a steam engine, I figured I had the concept pretty well down. I looked on Craigslist for a cheap two-stroke engine, but began thinking that Harbor Freight would probably have some knockoff brand, and for a few dollars more, I could have a brand new engine. So, I bought a 212cc Predator horizontal shaft engine.
After three days of stripping the engine down, cutting out an errant governor assembly that had fallen into the crankcase, and washing out the engine with degreaser and WD-40 - we realized that the engine was a four-stroke (my father sometimes gives me too much credit in thinking I know what I'm doing). Into the trash it went.
So, I looked online for a cheap chainsaw, and Lowes had a few, clearly labeled TWO-STROKE (so even I couldn't get it wrong). I came home with a 38cc Polan 18", and quickly stripped it down to the bare engine (keeping the frame for potential use as an engine bed). The seal between the cylinder and crankcase, I discovered, had no gaskets on this engine - the manufacturer had used RTB to hold things together. I made up some gaskets anyway, on the off-chance that they will hold oil.
Additionally, the parts for the electronic side of the engine are beginning to arrive.
One of the biggest problems I noticed with many of the well-meaning but ill-informed (or rather, just informed enough to be dangerous) videos about conversion from two-stroke to steam, is that none of the creators actually ran the engine on steam. If they had, they would have quickly discovered that their valves and fittings were not steam rated...
So, on to McMaster-Carr to order (under my father's direction) the proper electronic controls. We ended up with a 110V 40W solenoid valve from Magnatrol, and a basic reed switch, which will be protected from high voltage by a solid state relay driving the solenoid.
As it currently stands, the engine is sitting, in a few pieces, on the workbench, along with the solenoid valve, reed switch, and a casting kit for the 1880s feedwater hand pump from Pearl Engine Company, just arrived today via courier (downside of living in a new development in Buckeye is that, according to just about every map and GPS, my neighborhood doesn't exist. Google Maps shows the area as an empty dirt field - I just tell people I live in an underground bunker).
After the engine is together, progress becomes a matter of finding a dealer who will sell boiler tubing in small batches.
First, the engine.
