Reversing lever - loco style or clamp & rod
Posted: Thu Jan 02, 2014 11:24 pm
Hello all,
Happy New Year!
I am reviewing the plans for my York compound covering the details of the reversing lever assembly and got to thinking (that's always a bad idea
The reversing lever for the York is of the locomotive/quadrant style and has a spring loaded lever to hold the detent into the notch(es) in the quadrant. As drawn, the assembly is made from stock material but there was previously a drawing for a cast lever. I am thinking about building an equivalent to the casting from bar stock but would like to maybe simplify the mechanism if possible. Looking around at other engines, I find that there are several common methods used to hold the reversing lever in place. The other methods all seem to be a bit easier to construct than the pin & quadrant type and equally as serviceable.
Question is: I am leaning toward changing to a design of the clamp & rod style holding mechanism, is there any operational disadvantage of this type over the loco, notched quadrant type reversing lever mechanism? The only thing that comes to mind is that the loco style could be operated on handed where that would be difficult with the clamp & rod style (having to loosen the clamp knob while holding the lever) or is this not a factor?
Thanks
Happy New Year!
Thanks
