Building a Steam Launch
Posted: Mon Jun 29, 2015 8:41 pm
Hello All,
I joined the forum this past weekend and after looking around some of the older topics I came across the typical costs of a custom built Steam Launch, which started at $25,000 to $30,000 and upwards. Now, I had originally considered having a boat built by someone, but, to be honest, that's just not in my budget. So, doing a little research I determined that, with a little help, I should be able to build one myself, over the course of 1.5 years - 2 years (assuming I can keep a steady pace on weekends and nights). I have experience in mechanical and woodworking, so I feel that it should not be out of my skill area.
Before I get there, however, I do plan on buying literature and plans to go ahead and give myself a head start while I transition from school to working full time. So, that leaves me with some questions (some of them non-Engine and Boiler related, some yes) to kind of give me a feel on what I could/should be expecting.
1) Has anyone here built a hull from strip planking and, if so, how did it go? What type of hull did you choose, how many people helped you, how long did it take you, what facilities were you able to utilize, etc.?
One concern I do have is with the glassing, as I'm not particularly good with things of that nature. If you do it improperly what kind of problems will that leave you with? Bubbles, rough spots?
Are there any particular books or literature that you would recommend, both full hull building and glassing?
2) Has anyone here attempted and/or succeeded in building a boiler? I've got welding experience and like to think of myself as fairly proficient. Cutting the stock and material for the boiler would be relatively straight-forward, but the welding is what concerns me. Did you try a hand at the welding or did you let someone else take care of it?
Are there any particular books or literature that you would recommend for boiler building?
3) Building an engine, in my mind, is something I might leave to someone else, due to all the mechanical complexities required, but (again) who has built an engine from castings, or has even cast their own pieces? I've no doubt in my mind that, yes, I could do it, but I have a feeling it would be 'improperly' built.
4) Something I have already planned on doing is building a custom boat trailer (which I've built one before). Custom built to fit (that and anything smaller) with a toolbox and bunkers on either side for coal storage (probably waterproofed, for piece of mind...). Has anyone built their own trailer and what kinds of features did you put on it, frame material steel or aluminium, etc.?
5) Lastly, what are some good all-round books that you would recommend I buy, both for owning, operating and maintaining a steam boat, as well as just for pure enjoyment?
I think I've covered the basics, just to kind of start me off. All comments are much appreciated and I'm curious as to what y'all have done/think.
It's important to note, also, that I've not forgotten about buying a used boat. If one comes up and I have the money, I'll pop right in and give it a go. However, there's truly nothing as satisfying as building a piece of art and calling it your own, which is something I'd like to do myself.
-Ethan
-Ethan
