Steam Sirens
Steam Sirens
Well they go ON a boiler so I thought I would put this here.
I thought I would share a few photos of building sirens but I don't want to give away any secrets. (this post is intended to be a bit funny) So here are the siren building photos.
So who wants a siren???
Frank
Frank
Re: Steam Sirens
Not that I have a steamboat to put one on, but I sure do LOVE seam sirens!
Re: Steam Sirens
One of these would definitely be fun to have on a boat... Whoop Whoop Whooop.
Re: Steam Sirens
Well, I do have 5 availablebarts wrote:One of these would definitely be fun to have on a boat... Whoop Whoop Whooop.
Frank
Re: Steam Sirens
Wish the steam siren I got "new" that looks similar to these - but is not the same actually worked.
Sadly I can't spare the cash for one of these puppies, but they look great...
Re: Steam Sirens
Do you have a photo of your siren? What does it do/not do when you try and blow it. possibly it just needs a little "tweek" to make it work. I've done repair work on quite a few sirens (Starr Brass, Foster, Stevens and Sruthers)cyberbadger wrote:Wish the steam siren I got "new" that looks similar to these - but is not the same actually worked.
Frank
Re: Steam Sirens
Quite a common fault with home made sirens is that people tend to make them too precisely . The spool/rotor/whizzy-thing-inside-the-body should be a fairly loose fit .
My siren doesn't go whoop whoop whoop , it doesn't have a brake and was , I think , designed for a working pressure of 100-120 psi , certainly lower than my optimum pressure of 150-175 psi . Anyhow at my working pressure it screams like a banshee having its tail and one or two other parts of its anatomy twisted off.
Edward
Edward
Re: Steam Sirens
Edward,
Do they have some sort of bearing inside or does the rotor just spin suspended in a cavity?
Re: Steam Sirens
DetroiTug wrote:Edward,
The sirens I build the rotor just spins in a cavity. The new sirens sold by Preston Services in the UK also just spin in a cavity
There is or was a maker, Old Time Tech---Jerry Blain, their sirens are a bit larger than mine but I believe on theirs, the rotor is on a shaft that runs in a bushing/bearing.
Naval sirens made by Starr Brass had bushings, Foster sirens had bushings, Stevens and Struthers from the UK was a rotor spinning in a cavity.
Re: Steam Sirens
Several thing could be done to make it whoop whoop instead of scream like a banshee with it's tail on fire. the easiest may be to put a ball valve in the line and use it only for flow/volume adjustment. The other things that could be done involve making a new rotor that has more mass so it takes more time to come up to speed or a rotor with the same/more mass with slots that are sized and angled so it comes up to speed slower.Edward wrote:Quite a common fault with home made sirens is that people tend to make them too precisely . The spool/rotor/whizzy-thing-inside-the-body should be a fairly loose fit .
Edward
When I first started making these sirens I made 8 or 9 stator and rotor sets until I was satisfied with the design I use now.
Frank
