An idea for using waste heat
Posted: Sat Dec 26, 2015 7:33 pm
While working on the design of our proposed 37' steamer for use in the US Pacific Northwest, one idea that has been rattling around my head is to use a inboard plate-style condenser like Rainer's boat, but instead of cooling it using raw salt water we'd run a RV antifreeze loop and a keel condenser. We'd use the hot glycol mix to warm the boat (warm the cabin sole?), heat domestic hot water, and make sure the wet weather gear locker stays warm and dry before dumping the rest of the heat into the sea. A 6 roller Hypro pump would circulate the cooling water, using less than 1/8 hp to provide 7 gpm.
The pump would draw from a vented day tank; the pumping losses would likely amount to less than 10 psi. In order to regulate the amount of cooling, a portion of the flow from the pump could be bypassed back to the day tank. This would allow regulating the exit temperature of the condensate, and also keep the temperature of the circulating antifreeze up to insure proper heating inside the boat when steaming more slowly. The heating circuits inside the boat would each have their own bypass ball valves.
