Old Steamer wrote:RGSP,
Thank you for your reply. It was just the kind of detailed info on the pluses and (possible) minuses of the balanced valve system I was looking for. I also was not aware that the '6A-2' had extended columns. Are there any other tweaks I should be aware of?
I take it from your answer that you are using liquid fuel and assume that this is paraffin? If so, do you have any problem locating it in sufficient quantity?
Best Regards,
OS
As I don't have a 6A2 specification, I'm not sure all of them do have extended columns: mine does though. Mine also has a full simpling valve rather than an impulse one - it works, but it's a hefty, sticky thing relying on a large conical, rotating plug with steam passages cut into it, and usually needs two hands to turn it. Anyway, when all is well, reversing is very good in compound mode without disturbing it.
Having not had the engine all that long, I don't know how well the roller bearings will stand up to the rigours of a wet steamy atmosphere. However, the bearings are lubricated from a multi-way pressure feed, and the "works" are invariably oily rather than wet, so I live in hope
Yes I do indeed burn paraffin - grade C1 (lamp and heater) paraffin in fact. It's very widely available in 20 litre plastic containers, which my local hardware store sells at £28. Expensive, but the boat uses about 1 litre per mile, so in terms of the total cost of running a steamboat it isn't that bad. It's also available in 205 litre (45 gallon) drums at about £230 one off, reducing quite a lot for more than one.
The previous owner of the boat tried standard central heating grade kerosene, and it bunged the (vapourising) burner up, mainly as a result of the bio-fuel component as insisted on by the EU. He was running it recently on standard EU Kerosene + 20% petrol, which is claimed to avoid the clotting/char problem. A pressure-jet burner would almost certainly be fine anyway.
Having subsequently tested several burners with various fuels, out of the boat, and in the middle of my concrete farm-yard, I would strongly advise against using the above mixture. I was suspicious about it, and therefore wore a face-mask and anti-flash gear when testing, and boy did I need it! The fuel was fine until one of the jets went out for maybe 20 seconds and then re-lit: even straight paraffin would have flashed a bit after that, but this was seriously nasty, and would have caused major injuries if it had happened in the boat.
Burner testing was really because one of the burners I bought with the boat had failed catastrophically a few weeks before, and I wanted to test it and the others before refitting and using any of them in the boat. The failure was because the 1/2" plug in the end of the main vapour distribution tube was only soldered in (not screwed) and blew out, turning a nice, reasonably well-behaved, burner into a substantial flame thrower - quite honestly a bit frightening. The plug was brazed in, not soft soldered, but the braze had only wetted a very narrow ring about 0.5mm wide, visible from outside, and failed with a bang. When I started investigating, the other end of the same tube was sealed with something like car exhaust repair "gun gum", and leaked enough for a large candle flame. There WAS a screwed brass plug hidden under the black gunk, which had obviously been applied to stop a pin-hole leak and didn't work, but I only found that by drilling out and destroying it, and ended up inserting a mild steel plug and welding it into place, which seems fine.
The seller of the boat had a good reputation, but it's definitely a case of "buyer beware".
