Rudder tube construction for glass fibre hull
Posted: Sat Jul 21, 2018 9:07 pm
The re-fit continues...I'm now wondering about moving the rudder from the transom to an internal tube to (1) allow me to hook up a wheel with ease and (2) clean up the look of the transom. I've noticed some pulleys already installed in the area so I'm not the first to think about this.
What is the best way to make / install a rudder tube that sits below the waterline?
My current idea is to fit a fibreglass tube to the hull with epoxy / fillets / cloth, fit top and bottom bushes made from Acetal and support the tube with a few vertical ply webs. There is a shelf already fitted above the waterline at the back of the boat, so if I run through that as well, that the tube will be well supported top and bottom.
If I leave the tube long enough to be above waterline inside the boat I'll have no need to look at sealing it with a gland.
Am I on the right lines? Can anyone advise if this is the best way to do this before I start drilling holes in the hull!
Thanks
Thanks
