Wayward Belle
Posted: Sun Nov 29, 2009 7:57 pm
by 87gn@tahoe
Here is my steam lauch, the "Wayward Belle"
She was designed and built by Mr. William Charles Grosjean of Poway, California (near San Diego). Mr. Grosjean designed every aspect of this boat; he also made the patterns, boiler, controls, and engine himself.
The hull is a Chesapeake Bay style open launch, 22'-2" X 5'-10" X 1'-5". Sitka spruce frames and stringers. Honduras mahogany stem, keel, floor timbers and engine bearers. Bruynzeel plywood planking. Silicon bronze fastened and epoxy glued and sealed. Epoxy/fiberglass sheathed. Weight-850lbs
The engine is a 2" & 4" x 3.25" compound on six turned columns, stephenson link valve gear, piston valve on the high pressure piston, balanced slide vlave on the low pressure piston, independent valve gear adjustment on LP. Drip feed lubrication to bearings w/ oil slingers from main bearings to feed rod big-end bearings. Two feed pumps and two air pumps(condensate- 27in/vacuum when no leaks!) and one fuel pump dirven 1/4 engine speed ala Simpson Strickland style gear drive. approx 6BHP@700rpm. Weight-225lbs
The boiler is "once through" monotube, ASME approved design and materials. Natural draught, 21sq.ft./heating surface, 150psi, 450F, 200 lbs/hr. Controls similar principles to Doble "normalizer" control system. Vaporizing kerosene burner, modulated by steam pressure. Steam temperature controlled by quartz rod thermostat. Weight-220lbs
10 and 14 gallon fuel tanks, 3 gallon hot well, condenser: three 7/8" copper tubes 4.5' long.
Propeller- 15"x17" 3-blade
Mum getting warm:
Engine:
Clutch:
Action:
http://www.youtube.com/watch?v=nD8_nvSzz2Y
With my father up in the bow:
http://www.youtube.com/watch?v=Ec-oB7_J25s
Re: Wayward Belle
Posted: Sun Nov 29, 2009 8:31 pm
by piet schuurs
Hi Wesley,
Nice boat you have, and fitted out whit an beautifull engine.
I love the style of your Chesapeak Bay boat.
She looks very sturdy and runs well, as I've seen it on the movies.
Piet
Re: Wayward Belle
Posted: Mon Nov 30, 2009 12:52 am
by mcandrew1894
Great looking engine Wes! Fine job he did, and she moves!
Re: Wayward Belle
Posted: Mon Nov 30, 2009 1:49 am
by 87gn@tahoe
ALL of the credit goes to Mr. Grosjean. He engineered the boat to the 9th degree. Other than the running lights and a thermocouple that is never used, there are no electronics on the boat, all controls are mechanical.
I'm just a caretaker of sorts.
