Ofeldt water level?
Posted: Tue Dec 27, 2022 9:23 pm
What is considered the best water level to run an Ofeldt at? Top of the coils in steam space or water above the coils?
The drawings (SBA WTB2) show the top sight glass fitting about an inch over the top coil position suggesting that the water level should be a little below the top of the coils, but at some point in the past the sight glass has been re-located some 4 inches higher so that it straddles the top coil position. Bottom leg is off the water column, top leg is from the very top of the boiler. This has meant also meant a dog-leg in the bottom feed and naturally a higher water level.
Any thoughts? I'm re-casing the boiler at the moment; should I leave the glass high and run it with the top coil submerged or lower the glass and run with the top coil in steam space?
Cheers!
Cheers!
