Tiny Tech India
Posted: Wed Dec 29, 2010 2:18 am
Hello all. Someone else posted some prices for Tiny Tech India's boilers over on "my" thread entitled "Talk Me Out of It." I thought I would spin this subject off into it's own thread. Below are some more prices and details that I received from Mr. Desai back in March 2010. His engines are still being developed. I assisted him via email with some issues regarding his Stephenson link. Though I have not seem his work personally, thru many emails with him I feel that I have come to know and respect him. I can vouch for him as a serious and legitimate business man.
The quality of his engines and boilers might best be described as agricultural equipment. They are designed for functionality and economy of construction, not for aesthetics. If you want something of pretty with polished brass and hand turned columns, look else where. If you want something functional at a low price he is your man. I imagine anyone with real experience with small steam engines and boilers would be able to make many small improvements to his equipment, but you'll have a great place to start.
(1) STEAM ENGINES ONLY
(1) Single cylinder double acting steam engine 2 hp, cylinder dia 2"xstroke 3", complete with Stephenson link reverse mechanism, hand lubricating pump for cylinder lubrication, and 14" pulley. Weight 35 kg.(This engine is suitable for solar thermal power plant for home. We renovatted this engine by introducing Stephenson link reverse mechanism and now it is ideally suitable for solar power plant or even for tiny boat.)US$ 650/-
(2) Single cylinder double acting steam engine 4 hp, cylinder dia 2.5"xstroke 4", complete with Stephenson link reverse mechanism, hand lubricating pump for cylinder lubrication, and 14" pulley. Weight 70 kg.(This engine is suitable for solar thermal power plant for home. We renovatted this engine by introducing Stephenson link reverse mechanism and now it is ideally suitable for solar power plant or even for small boat.)US$ 1300/-
(3) Single cylinder double acting steam engine 5 hp, cylinder dia 3"xstroke 4", complete with reverse mechanism, hand lubricating pump for cylinder lubrication, drip lubricator for crosshead lubrication and 12" pulley. Weight 85 kg.
US$ 1400/-
(4) Single cylinder double acting steam engine 8 hp, cylinder dia 4"xstroke 4", complete with reverse mechanism, hand lubricating pump for cylinder lubrication, drip lubricator for crosshead lubrication and 16" pulley . Weight 100kg.
US$ 1600/-
(8) Single cylinder double acting steam engine 18 hp, cylinder dia 4.5"xstroke 6", complete with Stephenson reverse mechanism, hand lubricating pump for cylinder lubrication, drip lubricator for crosshead lubrication and 16" pulley cum flywheel. Weight 200 kg.
US$2400/-
(2) STEAM POWER PLANT 4 HP
Steam power plant consisting of (1) Single cylinder double acting steam engine 4 hp, cylinder dia 2.5"xstroke 4", complete with Stephenson link reverse mechanism, hand lubricating pump for cylinder lubrication, drip lubricator for crosshead lubrication and 12" pulley (2) Water tube Yarrow type boiler suitable for biomass firing with 45 sq ft heating surface including economizer and superheater, test pressure 300psi,working pressure 160 psi complete with water feed pump,water level gauge set, pressure gauge, safety valve, fire grates and 20ft chimney 1 set+ interconnecting pipe lines, valves, pipe fittings etc.Boiler is insulated with cerawool. Shipment volume 2 cu. mt.
COST US$3400/- with CD
(3) STEAM POWER PLANT 5 HP
Steam power plant consisting of (1) Single cylinder double acting steam engine 5 hp, cylinder dia 3"xstroke 4", complete with reverse mechanism, hand lubricating pump for cylinder lubrication, drip lubricator for crosshead lubrication and 12" pulley (2) Water tube Yarrow type boiler suitable for biomass firing with 54 sq ft heating surface including economizer and superheater, test pressure 300psi,working pressure 160 psi complete with water feed pump,water level gauge set, pressure gauge, safety valve, fire grates and 20ft chimney 1 set+ interconnecting pipe lines, valves, pipe fittings etc.Boiler is insulated with cerawool. Shipment volume 2 cu. mt.
COST US$3600/- with CD
(4) STEAM POWER PLANT 8 HP
Steam power plant consisting of (1) Single cylinder double acting steam engine 8 hp, cylinder dia 4"xstroke 4", complete with reverse mechanism, hand lubricating pump for cylinder lubrication, drip lubricator for crosshead lubrication and 16" pulley (2) Water tube Yarrow type boiler suitable for biomass firing with 80 sq ft heating surface including economizer and superheater, test pressure 300psi,working pressure 160 psi complete with water feed pump,water level gauge set, pressure gauge, safety valve, fire grates and 20ft chimney 1 set+ interconnecting pipe lines, valves, pipe fittings etc.Boiler is insulated with cerawool. Shipment volume 2 cu. mt.
COST US$ 4500/- with CD
(5) STEAM POWER PLANT 10 HP
Steam power plant consisting of (1) Double cylinder double acting steam engine 10 hp, each cylinder dia 3"xstroke 4", complete with reverse mechanism, hand lubricating pump for cylinder lubrication, drip lubricator for crosshead lubrication and 12" pulley (2) Water tube Yarrow type boiler suitable for biomass firing with 90 sq ft heating surface including economizer and superheater, test pressure 300psi,working pressure 160 psi complete with water feed pump,water level gauge set, pressure gauge, safety valve, fire grates and 20ft chimney 1 set+ interconnecting pipe lines, valves, pipe fittings etc. Boiler is insulated with cerawool. Shipment volume 3.5 cu. mt.
COST US$ 5600/- with CD
(7) STEAM POWER PLANT 1 KW
(For technical schools, engineering colleges, universities etc)
Steam power plant consisting of (1) Single cylinder double acting steam engine 2 hp, cylinder dia 2"xstroke 3", complete with hand lubricating pump for cylinder lubrication, and 10" pulley (2)
Water tube Yarrow type boiler suitable for biomass firing with 45 sq ft heating surface including economizer and superheater, test pressure 300psi,working pressure 160 psi complete with hand operated water feed pump,water level gauge set, pressure gauge, safety valve, fire grates and 20ft chimney 1 set+ interconnecting pipe lines, valves, pipe fittings etc.Boiler is insulated with cerawool. (3)Auto alternator of 1kw connected to steam engine. Shipment volume 2 cu. mt.
COST US$ 2800/- with CD
(8) STEAM POWER PLANT 3 KVA (FOR ELECTRIFICATION)
Steam power plant consisting of (1) Single cylinder double acting steam engine 8 hp, cylinder dia 4"xstroke 4", complete with reverse mechanism, hand lubricating pump for cylinder lubrication, drip lubricator for crosshead lubrication and 16" pulley (2) Water tube Yarrow type boiler suitable for biomass firing with 83 sq ft heating surface including economizer and superheater, test pressure 300psi,working pressure 160 psi complete with water feed pump,water level gauge set, pressure gauge, safety valve, fire grates and 20ft chimney 1 set+ interconnecting pipe lines, valves, pipe fittings etc. Boiler is insulated with cerawool. (3)Alternator maximum capacity 3 KVA, single phase, 240V, 50Hz driven by steam engine bybelts and pulleys. Shipment volume 2.5 cu. mt.
COST US$ 5200/- with CD
(10) STEAM POWER PLANT 10 KVA (FOR ELECTRIFICATION)
Steam power plant consisting of (1) Single cylinder double acting steam engine 18 hp, cylinder dia 4.5"xstroke 6", complete with Stephenson link reverse mechanism, hand lubricating pump for cylinder lubrication, drip lubricator for crosshead lubrication and 16" pulley (2) Water tube Yarrow type boiler suitable for biomass firing with 140 sq ft heating surface including economizer and superheater, test pressure 300psi,working pressure 160 psi complete with water feed pump,water level gauge set, pressure gauge, safety valve, fire grates and 20ft chimney 1 set+ interconnecting pipe lines, valves, pipe fittings etc.Boiler is insulated with cerawool. (3)Alternator maximum capacity 10 KVA, single phase, 240V, 50Hz driven by steam engine by belts and pulleys. Shipment volume 5 cu. mt.
COST US$ 9000/- with CD
(11) STEAM BOILERS ONLY
(1) Water tube Yarrow type boiler suitable for biomass firing with 140 sq ft heating
400psi,working pressure 160 psi complete with water
COST FOB INDIAN PORT US$ 5600/-
300psi,working pressure 150 psi complete with water
COST FOB INDIAN PORT US$ 4000/-
(3) Water tube Yarrow type boiler suitable for biomass firing with 83 sq ft heating
COST FOB INDIAN PORT US$ 3900/-
(4) Water tube Yarrow type boiler suitable for biomass firing with 54 sq ft heating
COST FOB INDIAN PORT US$ 2200/-
(1) If interested in any item, proforma invoice should be asked for.
(2) All products will carry video CD for operation, maintenance, assembling, commissioning purpose. No any CD will be sent in advance in any case.
V. K. DESAI
Managing Director
AADHUNIK GLOBAL ENERGY
TINYTECH PLANTS
Tagore Road, RAJKOT - 360002, INDIA
91 92 27 60 65 70 ( MOBILE)
91 281 245 5730
91 281 246 7552 (FAX)
tinytech@tinytehindia.com
www.tinytechindia.com
US$ 1400/-
US$ 1600/-
US$2400/-
V. K. DESAI
Managing Director
TINYTECH PLANTS
91 281 245 5730
