Stuart versus Semple
Posted: Mon Feb 27, 2012 9:40 pm
I have an 18 foot boat with a 7 foot beam. It was powered by a Semple 34dw single. The max boat speed was 7.5 mph. I wanted a compound engine just like my wife wants a new dinning room suite.
I repaired and completed the work of a "partialy built" Stuart6a kit I purchased on Ebay to replace the Semple engine. I swapped the engines thinking I would have ample HP and the Stuart would waste less steam (power). What I found was that the Stuart 6 would only move the boat at 5mph. I sought a method of prop measurement and I know now that my prop has a 16 inch pitch. I was thinking about changing it to a smaller pitch and let the Stuart 6 run at a higher rpm. However, this may result in using the same amount of steam as the Semple engine did. The Semple was certainly less finnicky.
In order to build the Stuart engine, I received all but one of the prints and no building method. I tried to obtain from Stuart the missing print and any build information they might have. I was told by them twice (several months apart) that their blueprint machine is not working. I had to make a few "best guess" decisions in order to get it running (it is running). If some of you run a Stuart6, pehaps you might kindly help me with a few problems I am having.
First I would like to know what type and size packing to use. I used 3/16 round and it kind of works. I tighten it and it seals but ten minutes latter, it is leaking again. I tighten again. I have not run out of packing nut thread but i have run out of hope that my packing is going to work.
The engine has "D" valves. If I tighten the slide plate to its shaft during timing, the steam pressure cannot seal the valve plate against the face. I had to use jamb nuts above and below it to position it verticaly w/o constraining it horizontaly. This allowed the valve plate to be blown tightly against the valve face. Was this Stuarts intended method?
My next question requires some "story". I am running along, ginning just fine at 80 psi. The engine begins to slow and 30 seconds latter, it has stalled. I turned off the throttle and took a lever to the flywheel bolts in order to turn the motor. I can turn it backwards with some difficulty. I don't think it is seized up mechanicaly. I can turn it forward with a little more difficulty. So, I rock it backwards a few turns and it seems to loosen up. I open the throttle, roll it forward and off she goes. Running just as well as it did before the problem. This scenario has repeated itself 4 or five times, different days, different trips. The water level was at about 3/4 in the sight glass or i would have thought it had flooded and hydraulically locked. I am puzzled. What might be the problem?
