Valve Gear & Cutoff
Posted: Sun Mar 18, 2012 12:58 am
The Sidewheeler Margaret S. has a simple double acting American Walking Beam Engine, with steam pressure typically around 80 - 90 PSIG. Running with exhaust to atmosphere presently, a condenser to be fitted later.
The valve gear on the Margaret S. engine is Marshall-Bremme, and the lever has 19 notches, Zero, 9 Forward, 9 Reverse, corresponding to +/-45 degrees rotation = 9th notch. Most of the time I run with the 5-6-7-8-9 notches, (25-30-35-40-45 degrees) which gives 55% to 85% cutoff. The engine will run with much shorter cutoff when on the trailer, but does not do too well in the water with shorter cutoffs, the steam pressure is just too low to make use of the short cutoffs. At full gear (9th notch) the beam driven feed pump can't quite keep up, so I have to use the hand feed pump occasionally, 6th or 7th notch and the boiler level will climb slowly without the hand pump.
I looked at this with an EXCEL spreadsheet, and came up with the Valve Lever Position vs. % Cutoff in the "Head End" and "Crank End" graph attached. This valve gear provides almost equal cutoff in both the head end and crank end, from 30% cutoff all the way to 85% cutoff, and is very nearly the same in forward or reverse. How does this valve gear compare with other popular valve gear with respect to equal cutoffs in full gear and linked up, reversed, etc.?
