And I too would very much appreciate a copy of your paper....
To get a triple
Re: To get a triple
Re: To get a triple
I downloaded Stumpf's book and have been easing my way through it. I am slowly coming to the realization that a 3 cylinder uniflow would be a better fit...smooth operation, and should be very reliable...if one or even 2 cylinders go down you can still run. The hard part is finding a proven design.
Anyone have a 4hp (or bigger) proven design they would like to sell?
Re: To get a triple
The Domestic Heat-Power machine burned anthracite coal, using an automatic stoker, running 24/7 requires a fully automatic plant. Send me your e-mail in a PM and I will forward the paper. I will not use the e-mail address for anything else.
A very high efficiency 3 cylinder uniflow engine was used to generate 25kW at the Whitecliffs Solar Power Plant in Austraila. Lookup details of this machine on the Internet.
Re: To get a triple
I looked at the White Cliffs design, they use a converted Lister and use an interesting valve operation. I also went to Elpenor's site. Does anyone know the hp rating of that engine?
- artemis
- Boat Name: Pond Skimmer
Re: To get a triple
According to a very comprehensive article on the building of that engine that David Ayers wrote for/and was published in Steamboating Magazine, at 320 rpm, 100psi, 45deg cutoff (about 1/6 stroke), 27" vacuum the HP rating is 8.Ralph B wrote:...I also went to Elpenor's site. Does anyone know the hp rating of that engine?
Ron
Re: To get a triple
Don't underestimate the simplicity and reliability improvements you'd get from a big single cylinder uniflow... with a overhung crank, you can easily use roller bearings for the crankpin, and mains can be tapered roller bearings or babbitt if you prefer. With poppet valves, a proper maneuvering cut-off (at least 50%) and auxiliary clearance space to reduce compression under low vacuum conditions, you shouldn't have any problems with the engine failing to reverse reliably.
- artemis
Re: To get a triple
Yeah, and you don't have all those tiny parts to wear out rapidly (wrist pin knock, etc.).barts wrote:Don't underestimate the simplicity and reliability improvements you'd get from a big single cylinder uniflow... with a overhung crank, you can easily use roller bearings for the crankpin, and mains can be tapered roller bearings or babbitt if you prefer. With poppet valves, a proper maneuvering cut-off (at least 50%) and auxiliary clearance space to reduce compression under low vacuum conditions, you shouldn't have any problems with the engine failing to reverse reliably.
