On the water testing of Folly
Posted: Wed Sep 12, 2012 11:45 pm
24’ by 6’. Plywood V-bottom. Displacement unknown. Fairly light.
Bicycle speedo tack and GPS for speed. Flat water and no tide currents.
Strath Warrego 3 x 4 piston valve single. 18 x 20 prop. Beckman VFT-30 boiler. 120-130 psi on the top speed run.
Rpm Knots
100 1.6
200 3.0
300 4.5
400 5.2
520 6.1
At 6 kts. the stern wave is impressive. Much flailing around of the engine. The motor mounts could use some additional stiffness. The sweet spot is around 300 rpm. My favorite is cruising around near shore or in a marina at 150-200 rpm. Total silence. Not even any fire rumble as the damper is closed and I’m burning fir which is fairly quiet.
I have another prop with 24” pitch. It will interesting to see what numbers I get with it. I prefer quiet rather than speed. We’ll see.
Now for better steering gear, an exhaust feed water heater, an economizer, and a blower for quick bursts of speed. The small Hypro pump has been completely trouble free once I solved some plumbing issues. It’s direct drive and always keeps ahead of the boiler and engine with a fairly low bypass flow to the hot well float. The keel condenser may be too big as the hot well is at about room temperature.
It has taken me several afternoon excursions to get the hang of firing with ordinary fir fire wood. As others have noted, one must plan ahead. Just now I startled my neighbors on the drive home (I live a half mile from the launch ramp). I was waving at them just as the safety valve popped on Folly. I’m sure they thought it was blowing up!
Rpm Knots
100 1.6
200 3.0
300 4.5
400 5.2
520 6.1
