Successful Steaming
wsmcycle
Successful Steaming
Post by wsmcycle »
I placed a new valve between the injector water intake and the hand pump (the air leaking culprit). I just knew that would solve the plaguing problem but it did not. I had two 5/8 Penberthys and neither worked so I decided to take the smaller one 1/2 in. off of my smaller boat. It had never failed me. I plumbed it in, pressured the boiler to 40lbs of steam, and it would not work either. I wanted to smash it in a punch press but i didn't. My mechanical engineer pride (not smarts )wouldn't let me give up. I decided to try again at 100 lbs. VOILA, it pumped. I remember the 1/2 in. injector working on the small boat at 20 lbs. I do not know why it would not work on "Fearless". INJECTOR ghosts. I put the new 5/8 on and it worked at 100 lbs. I let the boiler cool down to 80 and tried it again with success.
With my first alternate boiler replenishing device working, I headed for the river where I met another mechanical engineer and an MD friend. My launch method is to put a rope on the front of the boat, tie it to the back of the truck, launch with a good shove and then pull the attached rope over to the dock. I backed in, perfect backing, not too far down the ramp, the boat floated off of the trailer. Beautiful except the boat slipped the noose. There goes "Fearless" un-tethered, coasting across the inlet. S**t! I was ready to swim in but there would be no way to get a rope on her from "within the water". Fortunately, a fisherman in a flat bottom boat saw my plight and came to the rescue. He took me out to the boat and I tied the rope around the rear cleat. Man did I tell that guy how thankful I was.
We three boarded and I fired the boiler with charcoal (not such a high energy fuel but burns well). At 100 lbs, we took off. The boiler was about 1/3 full so I tried the injector successfully and with 5/8 a boiler full of water we took off.
With a new drive chain on the condenser pump and the supply pump, I headed out with confidence up river to the Lee Creek tributary. The River was flowing at 72,000 cf/s (40,000 is high) so going up river was a challenge. Occasionally I sighted a point on shore to make sure we were in fact moving up. We were out for 3 hours shocking folks with the whistle and cruising about. All worked well. We loaded the boat up at 8:45 PM, just as dark was creeping in. It was the first successful steaming on "Fearless". And it was great!!
LIGHT THE FIRE!!
Re: Successful Steaming
Congratulations!!!
All of us have had our 'issues' with boat handling at one time or another. I won't bore you with mine as it would take up too much of your time and I already have enough esteem problems as it is!
If I wasn't down on injectors anyway, your stories of sorting out would put me off even more. My engine driven pump backed up by a hand pump have served me well. I do have a Paul Breish duplex pump mostly finished but it will be plumbed so that most of the time it will pump from the makeup tank to the hot well with alternate valving for feeding the boiler. To be honest, it will get more use astounding passengers than being an important need.
Now that you have things reasonably under control, you can wait for the other shoe to drop. What will/can go wrong now??? (grin)
I have experienced the unteathered launch scenario too. In that event a woman in a kayak rescued the boat, and she had to paddle the 1 ton launch back to the dock, about 100 feet. What a woman! I guess she had sympathy for this old man.
Glad to hear you had a good day's outing....Keep steaming.....
It didn't happen to me and I have no idea what was going on but last Summer I went to launch at my local ramp and as I arrived I saw a smallish (20 foot?) power boat tied to the dock and no one around. Nothing unusual about that. What did catch my eye after I launched and tied up in front of the boat was that the trailer was still strapped to the boat.
I steamed up, spent a few hours having fun and returned to an empty dock and a parking lot containing only my truck and trailer.
Hope his bearing buddies were well greased.
Scenes lost to history.
Leaving the trailer lashed to the boat on the lake seems to work OK, but cruising speed does suffer somewhat.
Makes for a clean trailer I suppose.
