I was not quite four when the boat was launched, so only got involved involved once the plant was commissioned.PeteThePen1 wrote:Hi Fred
In the UK the boiler testers are bound by the Pressure Vessel legislation and must apply the same standards that they would apply to any pressure vessel, be it a locomotive or a power station. So rigorous annual testing is the rule. To get an initial certificate, the boiler must be made to a design that has been approved by a 'competent' person and come with the paper trail for the materials used and the details of the coded welder who has welded it up. This paper trail follows the boiler to each of its subsequent test events. You also have to bear in mind that you will not get insurance for a steam launch unless you have a boiler certificate or certify that the vessel is out of commission for maintenance, etc. If you don't have insurance most inland waterways will be banned to you. For SBA meets you must have insurance and a valid boiler certificate or you will be turned away.
However my experience is certainly as you say, the boiler is of a known and certified design, and made of the correct steel by a suitable coded welder, it was then tested when new, and again each year, with a hydraulic test at five years. We we retubed it 23 or so years in, the drum was inspected with the tubes out, and then a hydraulic test when recommissioned.
If your are regulation free it might all sound like a huge faff, however what it actually means is that all the infrastructure is in place, the SBA has a stack of signed off designs on file, and SBA Services offers a very competent inspection service at a very reasonable price.
When I am standing next to out boiler, with 30gallons of water at 200psi and 185 C (365F) I have to admit, I wouldnt have it any other way.
Unless you have a specific requirement due to the application, or desired to re-invent the wheel for personally enjoyment...PeteThePen1 wrote:Thus for non engineers [and engineers alike] the SBA boiler design library and SBA services the boiler testing and design evaluation service is a godsend.
