If you, or someone you know, is willing to perform said work in exchange for a set or two of castings, please let me know.
The engine is a 2" & 4" x 3.25" compound designed and built by Charles Grosjean (including him making the patterns). It sits on six turned columns, stephenson link valve gear, piston valve on the high pressure piston, balanced slide valve on the low pressure piston, independent valve gear adjustment on LP. Drip feed lubrication to bearings w/ oil slingers from main bearings to feed rod big-end bearings. Two feed pumps and two air pumps and one fuel pump dirven 1/4 engine speed ala Simpson Strickland style worm gear drive. approx 6BHP@700rpm. Weight-225lbs
~Wes
