Decking a Pontoonboat
Re: Decking a Pontoonboat
Barts was right on the money. I couldn't read the original(Left in photo) without fifteen minutes of squinting. The boat was not only build in 1985 - It's capacity is 1985 lbs.
Replacement capacity plate I got - Ohio Watercraft Divison said it was fine to use a replacement capacity plate if it had the same numbers and info.
In the Nyitra thread, a third 20ft 19inch diameter pontoon will be added from a loaner scrap vessel I got.
Code: Select all
pi=3.14159
r=19/2/12          - 19" dived by 2 for radius divided by 12 to get feet
r=.7916666666
h1=24                 - 24' pontoon
v1=pi*r*r*h         - Volume Calculation
v1=47.2547495736
v1*2                   - Times 2 for 2 24' pontoons
v1=94.5094991472
h2=20                 - Center 20' pontoon
v2=pi*r*r*h         - Volume Calculation
v2=39.3789579780
vall= v1 + v1 + v2 - Add Volumes
vall=47.2547495736 + 47.2547495736 + 39.3789579780
vall=133.8884571252
buoyantweight = 133.8884571252* 62.4
buoyantweight = 8354.6397246124
bouyantweighthalffloating = 8354.6397246124/2 - Half Submerged, Divide by 2
bouyantweighthalffloating = 4177.319862306
I have to subtract hull weight - I can only guess 1000.
So now I have roughly 3000 lbs? Is this calculation correct?
Deck is 3/4" new Marine Plywood. A/B grade. I'm used Blue Water Alkyd Primer paint. And Blue Water Alkyd Royal Blue Paint.
I like how it says, "Not for sale or use by the General Public!"
Bump.
Can anybody check my calculations make sense?
Would appreciate it,
I'd try to get a better idea of the weight of the boat as she sits at present, but your calcs make approximate sense.
Right now your boat can handle 2000 lbs w/ 2 24' pontoons. By adding another at 20', I'd think
2000 * (20 + 24 + 24)/(24 + 24) = 2833 lbs additional weight, assuming your additional
structure is proportional in weight.
The third pontoon has been mounted and bolted to the hull. The marine plywood has also been painted.
See my Nyitra thread for pictures:
http://www.thesteamboatingforum.net/for ... 005#p14005
fredrosse wrote:You can use 3/4 fir exterior plywood, exterior rated. But it will check with just paint. .
Listen to Fred CB! :cry:
I am currently not happy with my Deck paint situation that I used as described earlier in this thread.
Some of the sheets on Nyitra are ok. However, some of them checked as Fred said within a month!
Some steamboating stuff you have to learn for yourself the hard way.....
Fir plywood w/o glass will always check given time, even if you coat it w/ epoxy before painting.
