UK source of firebricks/vermiculite panels for boiler ?
ianrichards
Boat Name: Isambard
Post by ianrichards »
I’ve been looking at the various options of vermiculite panels available over the web, but before I buy is there any particular sort I should be looking at.
I’d prefer to buy a panel and then cut to size as I need some off cuts to make a small brazing hearth.
I was looking at 25mm thickness.
TIA
Ian
Re: UK source of firebricks/vermiculite panels for boiler ?
I would definitely check Black Gates Engineering. A model steam (Keith Appleton) youtuber is always picking up all sorts of great stuff from them.
I'm sure if you call or go in person and tell them what you are doing they can recommend something they have in stock.
Their website references Boiler insulation - but they don't say on the website exactly what they have.
http://www.blackgates.co.uk/index.html
Speak to a kiln manufacturer, they have it chapter and verse, and know who supplies what, from where, and how much.
Mike Cole
Boat Name: Blue Buccaneer
Post by Mike Cole »
Mike Rometer wrote:Speak to a kiln manufacturer, they have it chapter and verse, and know who supplies what, from where, and how much.
Yep to the above, I was given a old kiln, got mine out of that.
Mike Cole
gallanach
Post by gallanach »
Malcolm Duckett sourced the insulation material for his boiler from https://shop.vitcas.com/
gallanach
Post by gallanach »
Mike Cole
Post by Mike Cole »
gallanach wrote:Malcolm Duckett sourced the insulation material for his boiler from https://shop.vitcas.com/
Based in Bristol, I see. they seem to have a good range of stuff suitable for building boilers. Should they be added to the SBA website as a known supplier?
Mike Cole
ianrichards
Boat Name: Isambard
Thanks
Ian
steamboatjack
Boat Name: grayling
Post by steamboatjack »
Victas are on the SBA directory of suppliers and have been for some time.
Mike Cole
Post by Mike Cole »
steamboatjack wrote:Victas are on the SBA directory of suppliers and have been for some time.
I knew I should have checked :oops:
Mike Cole
